need help. i have about 1/3 turbo boost and same exhaust brake power.
Spoke w/ 5-Star Diesel Tech on WIF, Perf Mods & FASS
Rust in Tank
I have a 07 6. 7l 3500 manual and I only have about 1/3 of my usual turbo boost and about 1/3 of my usual exhaust brake power. The truck has about 25k miles. I replaced the fuel filter about 1500 miles ago.
I am not close to a dealer.
Any ideas?
Thanks.
turn the key to the "on" position then off 3 times quickly... the third time leaving it on. . then read the codes that pop up in the dash display
find a dealer asap!!!!! my guess is its emissions system is sooted up, the 1th generation 6. 7 is terrible until all the latest flashes and egr valves have been repaced etc etc, what kind of oil have you been running??? You know it takes special LE (low emissions] oil or it will foul up the woodworks
I have made it home, still no power. I had broke the orginal diesel filler cap before the holliday, and purchased an aftermarket one. Could this be my problem? I have also added a flatbed and extended the filler tube.
I took my truck in this am and all is working now. They said they found nothing when they scanned it. The turbo was producing 25# of boost.
Who has the best set up to delete the dpf, egr, egr cooler, and tuner?
Thanks.
took my truck back to the dealer of the 2nd time for the 2262 code and they are going to replace the turbo now, i was thinking of going with all the delete stuff to make this one last longer, truck only has 46,000 miles on it. also wanting to know if any body else and had there turbo replaced and this emission crap messed up another turbo that is why i am leaning tord the delete stuff.
