2nd Gen Non-Engine/Transmission Need help locating replacement window and door lock switch cover plate
Engine/Transmission (1998.5 - 2002) Tom O'Briens Dodge Greenwood, IN
2nd Gen Non-Engine/Transmission parts list.
On my '96, I pressed the door lock with my fingertip the other day, and the switch dove down into the door innards.
Pulled the switch back up, and removed the cover plate. The little "tab" that the switch locks into is broken.
The passenger side has been broken for a long time (wife likes to rest her feet on it)
I have googled, lived, called LMC, called rockauto... . no one seems to have these.
Went to a local wrecking yard, nada.
Does anyone know where I can get replacements?
Item is stamped with two numbers:
30505H
55216301 LH
Thank you for any help,
KRS
By chance is the part that you're looking for similar to the small clip on the right side of this illustration? Or might it be like the retaining ring shown in the middle?
If so, the clip is part number: 4796652.
The retaining ring is part number: 55215198
You can get discounted pricing from an online Dodge dealer HERE.
I pulled these part numbers off the 1994-96 parts manual.
Good luck,
John L.
This what you need?
The tabs are intact. The window switch has come apart and part of it is still in there. I'll let you take it out. How about $30 shipped?
Scott,
The tabs on the switch holder look good, however the bezel in the photograph above appears to be missing the rear bezel mounting tab (that holds it in the door panel). Mine has a wedge shaped piece at the very bottom, down by the dual-switch bracket.
The top has the metal clip tab, just like yours; but the bottom is different.
Wow, a new one is very expensive!
KRS
I don't know. I don't see anything broken off. Here's a little close up of the only thing that looks like it MIGHT have been broken.
Up to you, just let me know.
