need help more problems up date 8 4 01
Ram still down in drive way waiting for help or will have to have it towed to dealer for fix . As we have one other vehicle wifes ,I took her to work to day and the belt on the air cond whent out , stoped on way back got new belt at auto zone but do to hot eng and afraid to take off other belts as it a all day job to replace and wife has to get to work was going to do it Sat . Well to night after picking up wife and comming home lights dim dash lights indicators com on Batt 0z gas ect . Check trans light flashing and head lights getting dim . Kept going with hopes of making it home some others tried to make it impossible by getting in the way you know the feeling when you know that if it stops its all over . We made it home put it on charge looked the belt is still intact so it could be the altmator eng is hot and its dark . Ill be up first light see what I can do as we must have wheels . sure seems like bad luck comes in bunches like grapes . Hope some new ideas come from you guys soon , I sure could use some help as soon as possible . Ron in Louisville Ky
well after spending hours putting on fan belts alt ,air cond , pwr str ,to no avail , found that the pulley on the crank shaft is rubing on and cutting the head of a bolt holding the oil filter on the eng, seems like problem I have ben having is caused by the seperation of the pulley it has place for four belts V and Flat four groov . This oberservation by me has ben seconded by a guy that knows cars and at the shop I took it to man said it may be that it has rubber inside and is pushing back . It seems that it has ben going on for some time and just got worse . Sure hope they can fix it and it don't cost too much . well ill know some thing Monday on that . The Ram is still in the drive way , and I guess monday the hook is going to be called for and off to the five star , I will post later so this will not happen to any one again . I know that from now on all inline fuzes i put in will be of the rubber inclosed blade type with colored and numbered cost about a doller or less for the holder and fuzes buy them by the bunch ? well thats it for now . Ron in Louisville Ky drive way
