I have no parking brakes at all. The pedal definitely has the normal amount of travel and there is a good bit of resistance felt when pushing on the pedal like the shoes are being applied. That part seems normal.
But I left the brake on and shifted out of park without the engine running/key on and on a slight incline it just rolls like theres nothing grabbing in the rear at all. I could push it and it would roll
The cable under the body has no slack when the pedal is applied, tight as it normally should be. I want to get it inspected soon and know for sure it won't pass like this. Any ideas?
I'm thinking it's something inside the drums that's not doing it's job. If that's the case I'll have to pull both sides and check.
Phil
Phil
