Engine/Transmission (1998.5 - 2002) Need help on ID'ing the fuel line (out)
2nd Gen Non-Engine/Transmission Front Grill ? $#&*%(!
Engine/Transmission (1998.5 - 2002) looking for more upgrades
Trying to install my FASS system and need help on ID'ing my Out from the fuel tank. Please look at this photo and tell me which one is to teh VP44 - the one on the left or right. I don't have the tank down.
https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=82044&perpage=15&pagenumber=1
Also - I was told that the fuel line simply disconnects via a screwdriver pusinh a quick disconnect - suppose to be able to do this without taking the fuel tank down. Does anybody know about this?
The connectors are hard to get to at the top of the tank, the guy who said that must be a skinny SOB to get to it. The connections are a quick discon. you squeeze the inner loc tab that goes away from you in the pic, and pull (to the pass. side) up then the hose will pull off the fitting. there is a O-ring in the fitting.
The hose on the right on the top of the tank is the feed line.
On the filter I did, I just cut the hose behind the fitting, ran a hose from the tank to the filter then a hose back to the plastic line where the fitting was and used a regular clamp and hooked it up. good luck!
