Need help on NV4500?????
Dump bed on a 1st Gen ?
Time for my first post
I need a quick answer from the trans swap guru's... will a NV4500 that was previously mated to a NP241 bolt up to a NP205??? The trans in question has a 29 spline out put if that helps any..... :confused:
OK... . to bolt up the bellhousing from my NV4500, I need to get an adapter plate for a NV4500 model year? Does anyone know the part number? I assume that the A518 adapter plate and the manual trans plates are different?
ok i am doing or did am almost done converting my 93 w250 to a nv4500
wilh out a kit if you get a kit it will come with a bellhousing
i used a 94-up engine to transmission spacer and a nv4500
bell housing i have lots of pictures if you like i can send them to you
way too many to post
