Competition Need help on turbo ID
Off Roading Carrier Bearing Removal on a D44
Off Roading Axle Parts Source
Found a cheap aftermarket turbo for sale that I was told came off a 3rd gen, but NO IDEA what HP or application (power wise) it's for. It is a turbonetics turbo, with a turbonetics part number "T-15558" on the back of the (polished) compressor housing. 2. 75" turbine exit, 4" flange, approx 2. 35" compressor inlet (inducer?). Larger split scroll exhaust housing with no wastegate. Now that I look closer, it has "edge" cast into the exhaust housing.
I called Edge AND Turbonetics tech departments, and no one seems to have any idea what it is. :confused: Idiots... It appears to obviously be a 5. 9L Cummins application turbo, but I don't know what to put it on or how it compares to an S300 or HX40 for instance. I got it with the intention of putting it on my wife's '07, but is doesn't have the 90* coming out of the compressor. I also have 2 friends with mild (under 300 RWHP probably) 12 valves that are interested if I don't want it. Help!
I pretty sure that turbo is the one that edge/turbonetics put together about 3-4 years ago. If i remember correctly they were granaides. I would steer away from them.
