Engine/Transmission (1998.5 - 2002) Need help please with trans swap please
Engine/Transmission (1998.5 - 2002) Marco, Help. Broken CaTCHER
2nd Gen Non-Engine/Transmission All Shook Up!
My truck will not run after swapping out the nv5600 for a fully built suncoast. The engine will run fine on a breakout box but will not run with my electronics hooked up. PLease give me all your suggestions as I need to have it running by 5/2 it is very important. Thank you for any help.
TJ
Yes they are doing the swap and they are thinking the same thing. I am just getting nervous and was wanting some ideas just incase that is not it.
TJ
J&H in redding? They pretty good guys? I am in Lodi, CA and am having a problem with my boost pressure which is on another post and was thinking about taking it up to them.
Tristan
You are gonna need a new harness to get your truck to play nice with the trans. I do believe the ECM id different and the PCM is for sure.
Dave
To be safe I'd get both and probably the harness too, just like FG said----nothing more frustrating than changing one electrical part to find you need the other and then something else---good luck----chris
