As the user name implies i work on semi's the smallest motor i touch is a 12.7 but i recently took on a project for a friend and his little 5.9 common rail is kickin my butt the truck turns over fine but will not start at all ive checked pressure from lift pump and its a steady 7.5 my scan tool showed the cp3 was only putting out 19 and spiked to 50 while cranking so i repaced it big mistake seeing as i got no results pressures are same as before ive since then capped off one injector at a time to see it was a leaky nozzle or cross tube with no luck in find the problem the truck has no mods is a 2005 2500 and it just broke 200,000 miles
