Need Help! Transmission Acting Up Again!
remove front hub assembly
Transmission is acting up again.
Seems like for no reason the transfer case is effecting the ability to get the truck in gear. I haven't used the 4wd for a while.
I can drive for months and all is fine. This weekend the problem returned several times. I was parked on a hill and when I tried to put it in gear I heard/felt a loud bang in what seemed like the rear. The truck moved fine but then stated to slip while moving slow. From experience, I shift into 4wd and truck moves then I shift back into 2wd and all is good. I needed to repeat this a couple of time this weekend.
I had the same problem a year ago and I thought it went away.
Any ideas???
The loud bang was likely just the park pawl releasing - they can bang pretty good if they have a load on them (from being on a hill). As for the slipping: if the trans were slipping internally it would have put you in logical limp-in mode, so since I presume that didn't happen, slip must be either in the transfer case, or just slipping the tires. Were you on a slippery surface?
After thinking about, I'd agree the bang was the parking brake hanging up. Definitely was not tire slip. Audible noise coming from transfer case even though I hadn't used it for a while. I got to believe it's something in the transfer case.
