The temp got down to 18 deg overnight, that may not be cold to some but it's cold in Alabama. I went out around 10:00 and the temp was up to 28. Cranked the truck, it seemed a little louder than usual, but it's always a little louder when it's cold. Backed out of the drive and eased on down the road, everything seemed normal, then 1/4 mile later it died. I tried several times to restart, it would crank and then die in about 2 sec. Got it back to the house and pulled out the filter (4,000 mi on it), looked normal except for 2 little pieces of ice near the bottom. Drained the filter cup, the fuel looked normal and sloshing it around I could detect 5 or 6 little water bubbles smaller than a pinhead in the bottom of the bucket. Put in a new filter, cranked the truck and it ran about 1 min before it died. Next I pulled out the manual to figgure out my next move. Check the fuel heater and the fuelheater relay. Guess what ??? There was no wire going to the fuel heater. To keep it short the fuel heater and the WIF sensor had NEVER been hooked up
I finally found the plug for the fuel heater and plugged it in. Thinking I had the problem whipped I tried to crank the truck, now it won't even hit a lick. :{ I can hear the lift pump running (2 sec when switched on and about 25 sec when you bump the starter and turn the switch back to the on position) so I ASSUME that the lift pump is working properly. I can also hear the grid heater for the intake cycling. Any ideas or advice ?? Help
I also want to thank Dean Upson for going out in 5 deg weather with a flashlight and a cell phone to look under his hood to help me confirm the wire colors for the plugs I was searching for. What a guy ! Thanks Dean.
Fireman
Fireman
