I'm new to the forum, and I have a problem. Wondering if anyone else has experienced this one.
With Comp on 5x5 and throttle wide open, I can go through all the gears holding each gear to 2700 rpm truck runs fine. But when I hold any gear to 2700 or thereabouts and I engage the clutch and let the rpm fall back to idle truck dies most of the time or runs rough. If I re-engage the clutch and bring the rpm's back up when it's running rough the motor will smooth out. If I re-engage the clutch when the motor dies and put it in a lower gear while coasting motor will restart. With comp on 3x5, I cannot get the truck to die, but it will start to run rough after throttle has been wide open and clutch is engaged. With the comp off, the symptoms are the same as with it on 3x5 but so slight they're almost unnoticeable.
About a week ago the truck started to stumble under acceleration with comp on 5x5, and since it was gradually worsening I replaced the VP44. This helped with the acceleration stumble but didn't fix the problem on the deceleration side. I reset the APPS and replaced the 150's with my 100 horse injectors. Also drained the fuel tank, replaced filters on FASS and had codes checked. No stored or active codes showed up.
I'm debating replacing the cam shaft sensor next. Any suggestions would be appreciated.
RedneckRam
RedneckRam
