Hey Guys
My 95 all of a sudden won't start. I got in the other day, turned the key and nothing happened. Batteries are good, they are fairly new & I put a multimeter on them. Terminals are clean and tight. I looked through the archives under 'won't start' and found only a couple with problems similar to mine.
According to those posts, I checked fuses in the PDC & swapped the A/C & starter relays.
Anything else I should check?
I read in one post about shorting across the starter terminals to get the truck to start. But would that help me diagnose the starting problem?
Not sure that it would be the starter contacts as the starter was replaced only maybe 15,000 miles ago. Any way to check this?
Thanks guys, I appreciate any clues and all the good help I am able to find through responses to other guys posts.
