Need help will not start
Gage Kits / Type / Money
Mag-Hytek temp sensor?
was puting in guages and was going to see if guages work boost and pyro , started to back out of drive whent two feet eng stoped ,tried to start nothing Air cond not working windows will not close , door locks work ok lights ok . I took out all the wires that i had connected and will start from scratch on that have a five speed cutout switch on the cluch cut it out and twisted the wires together still no go , whent to power dis box swaped some of the relays (no spairs) whent to auto zone got a relay for dash 20 amp for windows no go . I'm back to squar one now , I put a tarp on each door and closed it on the tarp to keep rain out for the night . Any suggeations any one , Ill be looking all night in the book and standing by for any thing you fellows can think that may be the cause or cure . standing by thanks Ron in Louisville Ky :eek: :eek: :eek: :confused: :confused: :confused: P. S now its raining and I just about give up on the arcives seems like they have some information about any thing you don't need at the time . I don't seem to have the right questions for a serch no matter what is ask for . TDR is still the best , Ron :(
Ron,
Have you checked at the point where power hooks up to the fuse and relay box under the hood. I would start there and see if a fusible link has blown. I am not sure if it is the same as the 2001.
Originally posted by KWIKKURT
Ron,
Have you checked at the point where power hooks up to the fuse and relay box under the hood. I would start there and see if a fusible link has blown. I am not sure if it is the same as the 2001. [ /B]
Thanks Kwikkurt Ill sure look first light in the AM black night now and don't have a light and have ben out there all day up till ten thirty its twelve twenty one here in Kentucky ,again thanks Ron in Louisville Ky:)
I also had this happen. There is a fuse in the in-cab fuse panel (#14 or 15 I think) that ties in with everything on the truck. I blew that one fuse and truck was dead. No start, no run, no go. Check the in-cab fuses. Hope this helps. It's a 15 amp fuse.
Thanks for information
Thanks will try as soon as I finish this reply again thanks Gizmo 007 Ron in Louisville Ky :confused:
RON, Any luck with your Truck. (Sorry didn't mean to ryme).
;) :confused: I hope your are out Testing your new gauges!
Kwilkurt sorry for not sending a reply before , i posted a new up date you may have seen it gives what I found at the switch . also posted that windows are up thanks to fellow ramer Emddiesel see post on that. Thanks for your help still down but hopfull some ideas will come from you folks out there . again thanks Ron in Louisville Ky drive way windows up truck down :confused: :confused: :confused: :(
