Has anyone had a problem with the door latch on the bottom of the quad door. Mine is real loose and is causing the main door to not close tight. the screws that hold the latch on are very tight but the latch its self is real loose. it seems like maybe there should be a shim or something to keep it tight.
Also I have been hearing a noise that sounds like its coming from the rear end only when I make a right hand turn. It makes a sound like the tire is hitting a mud flap but I know its not. could it be something to do with the locking diff. yoke or something in that area. I had a f 150 that the yoke went bad on it but it was more of a clunking sound this is more of a squeaking or scraping sound. Thanks
