J
JRunner
Guest
Need some expert advice. Truck has been getting harder and harder to start for the last couple of weeks, finally died and would not start, luckily was at home when this happened and did not need to get towed. Over last couple of days i have replaced the fuel filter,fuel lift pump and added 5 gallons of fuel just in case gauge was not working,still would not start. After reading some articles on the tdr i tried cracking loose the injectors and cranked it over, after about 5 seconds fuel started to shoot out. So i tightened them back up and tried starting it again, it started right up, i left it run for about 10 minutes and shut it off, waited for about 5 minutes tried it again and it would not start again. So i went through the whole process again, and same thing happened started right up, shut it down and would not start again. Any help or suggestions would be greatly appreciated. thank you.
