I am replacing my ball joint. u joints and hubs on my 2006 2500 4x4.
I started on the passenger side.
I have the rotor, hub,axle with u-joints out but I can figure out how to get the steering knuckle out because the tie rod end is holding it on.
the knuckle is loose from the ball joints.
I have the nuts holding the ball joints still on but loose.
I have removed the nut holding the tie rod to the knuckle but cant fiqure out how to remove it without beating on it which I dont think I should do.
Could some one please advice me as to the proper procedure to get the steering knuckle out so I can get to the ball joints.
I have seen the DIY posts with the pictures but they show the drivers side removal not the passenger side.
My truck is up in the air on jacks.
Here is my cell.
360-302-1083.
I will be up by 8 am
Thanks so much
Here is my cell.
360-302-1083.
Thanks so much
