Need help with codes
Why not use blow off valves??
TST 16 cm turbin housing help
I know this has nothing to do with your question, but I was wondering how you guys are pulling up these fault codes. Are you using some sort of lap top computer? Or do they appear on you digital mileage read out?
PO234 is turbo boost has been exceeded
The other code states blah blah blah a code has been set in the ecm and pcm...
Clanders, just turn your ignition key on the off 3 times and on the 3rd time leave the key in the on position and in the digital odometer it will give you a code,if one has been set off.
John
Bob,
Does this mean that the PS Boost Moduale isn't working?
How do I clear the codes? I have disconnected the battery for the night. Will that work? Thanks for all of your help, Greg
Greg, leaving the batts. disconnected will only clear the check engine light, the codes have to be removed via a scan tool. If the connections are tight, give Practical Solutions a call and see what they think. You shouldn't be setting overboost codes with a boost module.
Scott W.
