Ok folks, I appeal to you for your infinite wisdom as the dealer cannot find out what is wrong with my truck.
On 02 Apr, I transferred from NY to CA and on the way I noticed that everything under, around, and towed behind was covered in an oil slick. I immediately brought the truck in and they said that the Vacuum Pump seal had let go. While waiting for the pump to come in, the truck started to get a really long crank time before starting. Took 2-3 times w/ letting the LP timeout before starting.
The LP was replaced as it was found to have below spec pressure. The truck still had trouble starting but not as frequently. I brought it in to Seattle and had them check it out and that last pump (<1,000 miles old) had also failed and was replaced. Now the truck really has trouble starting. Almost every restart has problems. One thing that I noticed in common was the fact that the fuel tank was below 1/2 when it really starts to do it. When it is full, it is only once or twice.
I really need help in pointing the dealer in the right direction since they do not have a clue and follow my lead with a dealer proclaimed, "you know more about it than we do. " Should I be scared?
I can't afford for my truck to be down like this. If it ain't fixed by Tuesday afternoon, I trading it in on a '04.
Thanks!
Vinnie
BTW, 63000 miles on it and on it 3rd LP and 2nd Inj Pump. Has a new fuel filter.
Thanks!
Vinnie
