Engine/Transmission (1998.5 - 2002) need help with milage
ok, my 2001 2500 4x4 with an auto and 4. 10s now has 57000 miles on it and is earning a very good 21mpg. Only mods are the EZ and K&N. Now the other truck, the 2000 3500 4x4 has 65000 miles and i am only getting about 16mpg. Granted the truck has a slide in dump bed with a headache rack that sticks up about 6 inches above the back of the cab, but it has slots and shouldn't grab that much air. This truck has a 6 speed, 3. 55s, 4" exhaust, K&N, and a Powermax 3 on setting 5 for highway. I am basing these milage numbers on long highway journeys averaging 70-75mph. What gives for the lower milage on the 3500? I am also considering 275 injectors. What gain can I expect? What should I do for the present to get the milage up? I am driving to Michigan Tuesday (12 hours all highway) and would like to see closer to 20mpg or better. Thanks, JOE
Well, the 3500 should weigh considerably more than the 2500, you have 6 tires on the ground with rolling resistance vs 4 plus the duals stick out and catch air.
What did the trucks get before the EZ and Powermax? The 2500 is a little above avg. and the 3500 a little below. A friend of mine gets 16-17 on his 98. 5 24v 3500 at about 9000lbs. I get 19-20 on my 99 2500 QCSB at 6800lbs. both trks are stock 5spd and 3. 54; I do have a 4" exhaust.
Have you taken into account any changes/errors in tire size, speedo, etc. in figuring mileage?
Need help?
If you need help then what do I need? I've got a 01. 5 2500 QC SB 4x4 6spd with 4. 10 and the best that I've ever gotten was 18. 5. I've got a BHAF and 275's. My last tank was 15. 8. My EZ will be here on Tuesday so I'm interested what my mileage will be when I get it installed. That is, after I get done playing with it.
