Need Help with power steering upgrade
Darn it !!
Still No Cruise Control
I have a 89 non/ic and i had broke the eccentric shaft in the stock power steering pump and cannot find just a eccentric shaft at all. so i have found a pump that's for a 1994 model and was wondering how i done this. I know you have to modify the bracket for my throttle and run a oil line to the star screw on the block. But how does the brakes work if i don't have the diagrams or any of that
the 94 pump should be the same as what you have, unless you have a hydro booster which didn't come on trucks till 97 your power steering pump will have no effect on your brakes.
I have been told they're different on the non ic trucks and the intercooled trucks.. And they do look different because they don't have the diaframs or anything
