bigceltic
My trans (48RE) is leaking at the 8-pin plug (OD solenoid) and I want to replace it - and have to remove the valve body to do so. I have the ATSG manual, but it is not clear on how to remove the external manual shift lever after removing the Throttle valve actuator. Mine has a cable attached and it looks like it just pops off (Pic 1 arrow). But the ATSG manual completely skips over removing the external manual shift lever (figure 64 shows it removed but how!?) Do I just loosen the nut and pry it off? Do I need to mark its location before removal so I can put it back exactly in the same position/orientation? Using the BD valve body instructions that I saw recommended on here, I see it says to "On trucks equipped with a shift cable, pop the end off of the shift lever" - ok, so just pry that off. The BD instructions say to "Loosen the shift lever pinch bolt and remove from the transmission" - but mine seems to have an additional c-clip on it (see arrow on Pics 2 and 3).
Any pointers, help, guidance appreciated!
Also, it seems to be leaking from the front band adjustment screw - is that bad? 186K on the orig transmission, FYSA.
Thanks
George
Picture 1:
Picture 2:
Pic 3
Thanks
George
Picture 1:
Picture 2:
Pic 3
