Details here: TDR Privileges
A friend is trying to do front wheel bearings on Toyota 4runner 2 wheel drive and can't see what holds the hub , no bearing cap, nut & cotter pin etc. any body with knowledge would be greatly appreciated. Thanks Joe
Those are a press-fit bearing assembly, looks like this:
That unit bearing is pressed into the spindle so special tools would be needed to get the job done. On these you wouldn't take them apart to do a repack and only change it if it's bad.
