need help with trailer light adpter???
Generac Quietpact Q55G
suggestions on gooseneck horse trailers
i bought a adpter from TSC for a 7 rv hook up{on a 01} to a 6 pin round and when i hooked it up the trailer brakes lock up??? has any body experienced this problem??? And any help would be helpful Thanks Justin:confused:
It's actually pretty common. Unlike the 7-pin RV plug, there's not a formal convention that everyone uses on the 6-pin plug. Often you'll find that the 12VDC battery charging lead and the trailer brake lead are switched on the 6-pin wiring. That sounds like the situation you're facing - you're powering the trailer brakes off your 12VDC lead from the truck when you plug in.
To fix this, if you have access to the internals of the 7-to-6 pin adapter, swap the 12VDC and trailer brake leads going to the 6-pin side. If not, you'll need to swap these wires on the 6-pin plug on the trailer - of course, depending on how his truck is wired, the next guy that uses the trailer might have to switch them back! :rolleyes:
Here's a link to the trailer pin connectors on the 7-pin plug. Note that this illustration shows the location in the 7-pin connector mounted on the truck - the 7-to-6 adapter will have the same pin numbers but will be a mirror image as you look at the adapter plug face. 7-pin plug
Rusty
RustyJC is exactly correct. I had this situation last year when I borrowed my father in law's trailer that he pulls with a Ford:eek: I had a fit trying to figure it out. You would think there would be a common wiring patern everyone follows. The wire lug for the 12v constant hot is locking your brakes as soon as you plug it in. Hope this helps good luck
Thanks
Thanks for the replys, as soon as it gets warmer out I will check it out ansd change it around and poat results thanks vary mutch
Justin
