Ok guys. I have 77,000 on my 24 valve and the transmission is starting to act up. In overdrive, it cycles back and forth using slight pressure on the pedal usually from 46mph to 55. I understand the whole under 50 cycling and it has been there when I first drove it but know it has increased to higher speeds and is very noticeable. I have never taken it to the dealer and I am a little leary. Any ideas on the problem?
While I'm at the stealers I want them to check the steering box and and the lift pump... is there anything else I should have them check?
Thanks as always.
PS All I have on it for mods is the plug-n-play.
PSS The transmission flash was done before I bought it!
Dev
Thanks as always.
Dev
