From the powertrain diagnostics manual:
P0107: Inlet air pressure sensure voltage too low.
Set condition: the circuit voltage to the ECM falls below a calibrated threshold for a certain period of time.
Possible Causes:
-Inlet air pressure sensor
-Inlet air sensor signal circuit shorted to the return circuit
-Signal circuit open
-Supply circuit open
-Signal circuit shorted to ground
Tests:
1. Disconnect the inlet air pressure sensor harness connector. Check/clean/replace the connectors as necessary. measure the voltage between the supply circuit and return circuits of the sensor harness connector. If voltage is between 4. 5 and 5. 5 volts, test passed. If not, supply voltage is too low.
2. While monitoring the OBDII port, use a jumper wire to connect the 5 volt supply circuit with the signal circuit at the sensor harness connector. If the OBDII port indicates pressure sensor is out of range high, replace the pressure sensor.
3. Disconnect the ECM harness connector and measure the resistance between the signal circuit and the return circuit in the inlet air pressure sensor harness connector. It must be greater than 100K Ohms.
There are several more tests, but they're mostly meant to eliminate a wiring problem. If you try these tests and come up negative, I can help further.
P1740: TCC O/D Sol Performance
When monitored: The Torque Converter Clutch and Overdrive Clutch will be tested each time the PCM requests TCC engagement in 3rd gear and O/D.
Set Condition: The code will set if the expected RPM drop is not achieved while attempting to engage TCC or O/D. This indicates a malfunctioning torque convertor or overdrive clutch.
There's a lot of tests for this, I won't go into here. If you want more I can give it to you.
Hope this helps!
