Need Help!
19.5" Wheels & Tires -- Anyone Done This?
Scam WARNING
Hey guys,
I am putting a Jacobs exhaust brake on my father-in-laws 2000 ram. I ordered it with the plunger switch (on the gear shift) from cummins. The stock rocker switch had a green / yellow / red / white wire. The plunger switch has a green / yellow / red / black wires.
When I hook the rocker switch up the brake works fine. When I hook up the plunger switch I get nothing.
Can somebody please tell me what the heck the 4 wires on the plunger switch are suppose to go to. . The wiring must be different.
Thanks guys!
Update
Okay,
On the plunger switch, if I give the red wire 12v and use the black as the ground, the light lights up when I pull the plunger out. However the yellow wire does not send any voltage out. On the rocker switch they sent with the unit, the yellow gets 12v out when you flip it on.
Starting to think he may not have this plunger in by tomorrow.
Klenger where are you????????
