Engine/Transmission (1994 - 1998) Need Help
Engine/Transmission (1998.5 - 2002) Fule pressure gauge
Need Help (FUEL LEAK)
I have a fuel leak on the drivers side of my engine and can not find it. can anyone give me any ideas where to look now.
here is the thread i started in the 911 section.
LEAK
Sounds like the rubber fuel line that goes behind the injector pump. Just did mine this summer because of the same thing. The diesel fuel eats the type of rubber that the factory puts on. If your going to do it take off the starter and try to get it. Thats how I did mine. Was a booger!
WD
Along with removing the starter, disconnect the front drive line. That gives about the best visibility and access.
While you are under the truck, wipe everything dry then pump the primer button a few times, watching for the leak. I found mine that way. If it turns out to be a hose, which is most likely, you can get a set of replacement hoses from Foster Truck in Tacoma, WA. Two 2' lengths of hose and 4 clamps for about $25
It takes two sizes, 5/16" and 3/8"
