Engine/Transmission (1998.5 - 2002) need help
Engine/Transmission (1998.5 - 2002) Fried Adrenaline
Engine/Transmission (1994 - 1998) Move batteries to truck bed?
:confused:should i stay with my banks ottomind which it seems not to be working wright. no power from the get go. i've had it for about 5yr's now. iam thinking on getting the edge comp. can anyone tell me if this would be smart. i pull a 20008 33ft fithwheel. thanks.
I've been towing a 40' enclosed car trailer wt btween 10,000-11,000lbs. similar set up as your rig. using the edge comp pump wire tapped with BD stealth cover. I run it on 3-3 setting when towing no issues with egt. just need to keep an eye on temps when pulling a long grade. need to update my sig. Installed the comp about 2 yrs ago.
just turn down the box when you tow.
I have a used one for sale if you are looking for a cheaper unit.
Jacob
Most Banks products don't add much fuel until around 8lbs of boost. That way they don't add any low boost smoke.
The edge comp and quadzilla adrenaline seem to be the 2 best right now.
John
