Archived Need Info On Replacing Turbo Oil Drain Inlet
Archived wont turn
Archived No Brake Lights
My turbo oil drain inlet is leaking where it enters the engine block. The metal elbow is actually loose, I removed it while attempting to troubleshoot the details of why it was leaking. It appears to be a press fit into the block, no gaskets or O-rings. Has anyone ever had to replace this piece? I appreciate any help... Thanks!
Oil leak
Wipe the oil off the pipe and the block and put a bead of Loc-Tite Retaining Compound on the pipe. As you slip it together, rotate it to spread the Loc-Tite. Let it set for an hour before you assemble the hose to it. It should be "better than new".
CPFF
CPFF, thx for your reply. That was my orignal plan, however, the tolerances between the metal elbow and the hole in the block are VERY tight. I have been wrestling with this little tube for 2+ hours. I was hoping somebody might have a trick/tip/advice on how to press this @#$%^& tube back into the block. Thx again...
