STEVEBROOKS
Hello all,
I'd like to get your inputs on several questions, namely:
A. What is the max EGT I should run my engine at for sustained periods on the highway while towing?
B. What is the max very-short duration EGT for my engine while towing?
C. What do you consider the best shocks for my truck, considering approx 90% of my driving is around-town, and 10% is towing the toyhauler mentioned below (9K lbs fully-loaded)?
D. Have you drilled/tapped your top ball joints for grease fittings? If so, how well did that work and do you have any advice for doing so?
E. Do you have any experience in using the "airtabs" offered in the Geno's catalog? If yes, what, if any, fuel mileage/stability gains did you realize?
Thanks!
Thanks!
