Engine/Transmission (1994 - 1998) Need MOPAR part numbers
2nd Gen Non-Engine/Transmission steering boxes
Engine/Transmission (1994 - 1998) 2nd Gen Auto Transmission
I need the MOPAr number for:
Fuel Supply Line Fitting Grommet- Cummins part number 3923194
I can't make it to DC due to my work schedule and need the number so I can send family after it during the day.
Any help would be great guys.
Thank you.
Don't have the number, print and fax etc. this to your dc parts jockey so they can identify the "grommet" then I bet they order it right up (see below).
I'd also change the "supply elbow too. " (between the heater bowl and lift pump). Mopar number: 4883978aa/4746638
Thanks for the help. I went and talked it over at my DC. They can't get it. No part number, or even an arrow as your schematic shows too.
I checked with my cummin distributor. The local guys don't have it, my regional guys don't have it (Cummins Highland), and the part itself was $4. 80 and $15. 50 to ship it, I guess directly from fleetgaurd, to Somerset.
I think i'm just going to eliminate it with race hose and call it good. A previous ower had tampered pretty heavily around the area where the fuel lines run down over the bellhousing. I'm physically too large to place them back where they belong in their brackets but I can take them loose and slide them out. I'm just going to do that and clean it up. With any luck i'll be back on the road next week.
You can replace the fitting with a different type. One guy I know who had a bad grommet did that. I think he used barbed fitting and a longer supply hose.
I think I trashed my grommet during my new lift pump install while the pre-filter bracket was loose. If anyone else checks it out. . beware.
