2nd Gen Non-Engine/Transmission Need More Help... Rear Wheel Speed Sensor...
Engine/Transmission (1994 - 1998) Shame on Me!
Engine/Transmission (1994 - 1998) trans problem
I've tried Haynes, I've tried the Owner's Manual. Can anyone show me (preferably a photograph) exactly where the rear wheel speed sensor is??? See Sign for description of vehicle. I checked the fuse, I've gone over (and over and over) the wiring and I find nothing. I, too, was running in adverse conditions (read rain) as others have previously written, but still I can find no visible problems. If I knew where the sensor was, I'm sure I could replace it. Much appreciate all of you help! Thanks!!!
Lay under your truck. It's on the top foreward driver's-side of the differential. Its the only thing with electrical wires going to it.
Mine broke off too. I couldn't get ahold of it and had to use a 3" wood screw to screw into the plastic to pull it out.
Justin H.
Any ideas?.?.?
Okay, does anybody have the P/N for this thing so I can just go get it from the dealership? I called and the guy tried to tell me that there are two of them (one for RWAL and one for all-wheel anti-lock)... I've talked it to death so the first one to reply w/ the P/N gets my prize for being the 100,000th person to have one break while being removed (assuming no legal responsibility if it doesn't break... ) :D
Mark
