Archived Need oil pan and oil pump pick up tube 91 Diesel
Archived HELp quick.....Speaker install 06 dodge
Archived help!!
1991 Dodge 350 w/Cummins Diesel. Ran over post and pushed oil pan up and broke oil pan pick up tube. No part# found. Eng SN# plate gone from engine.
Macon, GA
THANKS, GUYS, MY SON GOT THE PARTS. . THANKS TO THE GUY WITH THE NEW OIL PAN, BUT YOU DID NOT GET BACK TO MY E MAIL. DICK
Macon, GA
I have a brand new oil pan,gasket and drain plug sitting in the shed. I ordered them for a 2001 Ram 2500, dont know if they will fit your year.
Part #'s
Oil pan 5080632-AA
Pan gasket 5003694-AC
Drain plug 5080631-AB
Drain plug gasket 4882049
I paid around $265 for everything, I'd sell it for a $100. 00
From alldata (not always the most up to date and accurate site though)
OEM part numbers for 1991 dodge truck 350 with cummins,
oil pan - 4429403 - 377. 00
oil pan gasket - 5003694AA - 35. 45
oil pickup/strainer - 4429506 - 179. 00
The procedure for replacement says you have to pull the engine? :confused: With a little over 10 hours for with auto trans and more for manual trans. Wow, I hope there is some way to get around pulling the engine??
The manuel for 2nd gen trucks says you have to unbolt the motor and trans crossmember,then jack up the motor 4" or 5" and put blocks in between the motor and motor mounts. This gives you the clearance to then remove the pan and pick up. .
