how did the 90 degree elbow on the bd turbo,line up with the hose going to the intercooler,seems like it is going to hit my brackets that hold my shocks,did youres line up okay???also did you have to get another downpipe and clamp or did youre factory one work,I have and 03,here a while back I put a 4 inch downpipe on it,hope I wont have to get another downpipe to fit the turbo!!!!!lil red cummins said:on the regular super B, there are a few issues. i am not sure if these apply to the super B special but here they are:
had to grind a little off the motor mount to clear the waste gate control.
i also had to cut my exhaust front pipe to move it back farther than the mounts would let it move. i took out about 2" and just put a coupler back on.
you need a thin wrench or swivel socket with long extension to get the 2 inside flange mount screws on the manifold.
many recommend removing the right inner fender and air box for better access. i didn't do it and probably should have.
make sure to loosen the intake and exhaust housing clamp screws to "clock" your housings to the correct position.
don't cut the hose going to the intercooler (stupid mistake) just compress it a little.
those are the things i remember most as trouble spots.
good luck,
jim
kdbvulcan said:how did the 90 degree elbow on the bd turbo,line up with the hose going to the intercooler,seems like it is going to hit my brackets that hold my shocks,did youres line up okay???also did you have to get another downpipe and clamp or did youre factory one work,I have and 03,here a while back I put a 4 inch downpipe on it,hope I wont have to get another downpipe to fit the turbo!!!!!
daytripper63 said:I have about 3/4" clearance from shock tower on my 03
kdbvulcan said:did you need another downpipe or did youre factory one work,also how did youre 90 degree elbow line up with youre intercooler hose????
daytripper63 said:Here you go, the photos were to big to go to my TDR photo gallery so I sent them to my Yahoo/Flicker gallery, heres the link
http://www.flickr.com/photos/daytripper63/
Double click the photos to enlarge
kdbvulcan said:Hey do you know if Genos Garage sells those blue hoses seperately or not,I appreciate youre help
how did youre 90 degree elbow on youre new charger,line up with youre intercooler hose?????lil red cummins said:sorry for the delay in responding.
i was able to rotate the inlet housing high enough to clear everything.
my truck is 2WD, there may be clearance issues with 4WD.
jim
