How do you get the small pulley off the shaft of the harmonic balancer. I have removed the set screw and it should pull off but no way. HELP
jraker said:My question to you guys is I don't show any fuel pressure on startup. My gauge says 0 until the engine is running. I thought the LP was supposed to run if the RASP was below 8 psi? Is this normal for you as well?
