need recommendation in Portland,OR
you gotta love this
Cruise Control
I am looking for a shop between Portland,OR and the coast that knows how to set injection timing... . to 14 or 15 degrees BTDC.
Thanks.
1997 4x4 CC 5spd, CPL1553 pump, Horton fan, Sport headlamps, Optima RedTops, 98 shift levers and console, RS5000 shocks, Yaesu VHF radio, and BCT7 scanner in the overhead console... N7DAL.
Four hours is a little long for an experienced person to set the timing using the dial indicator method. I watched and helped with my truck, and it only a little over an hour. Other methods may take longer, I don't know.
Brian
Does anyone know if Jim Leonard does this?
Money Sink - 96, 5 speed, HX40-16, TST #11/280 slid 3/4 way, 300 HP Injectors, Scourge BD 4200rpm Governor kit, McLeod, 4", CATless, straight out back, chrome turn down, ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Mag-Hytec, 3:54, Michelin 235s on Alcoas, Rancho 9000's, Valentine One.
#11 plate days are numbered, custom grind in hand.
Dutchmen 27' 5th Wheel.
GoldWing.
Check out R&G machine in Molalla. Ive seen their adds in the nickle adds. I called them once and they said it would take around 4 hours to do. I still haven't had the time to drive up there and get it done yet.
Good Luck
Brian Cobb
97 2500 CC 4x4 5 speed,egt & boost gauges, #5 tst,370hp injectors,4" exhaust,16cm turbo,Governor spring kit
afc kit,Pro Shot 2000,RE-0880, ceramic brass clutch,prozap
[This message has been edited by Brian Cobb (edited 01-28-2001). ]
R&G Machining & Engine Parts 503/829-6038 (123 N Molalla Av). The gent is an ex Cummins tech and has a very good reputation around here. Also has a dyno if anyone is interested. He liked to play with hp and is now playing with mileage numbers.
