Need Replacement Mirror assembly for driver side
Are these tires legal/safe?
Rhino or Line-X????
I did the flip up power/heated mirror conversion, and the drivers side has cracked, and now the mirror assy is way loose... are there any good sites to get these parts for cheap? I looked at the other mirrors, and it does not appear that I can put the manual mirror on there to make it work. . I am going to take one to work to see if I can, but please help me out here!!
-Chris-
its not the glass, but the pivot point on the actual mirror assembly that enables you to flip the mirror up and out to be 40 acres away from you. the glass is fine. . I just need help getting the other piece fixed... I tried some JB weld, so we will see how that holds up...
-Chris-
