Need Rims
Auto transmission Searching for Gears...
RPM in high gear
While getting an alignment, I found out that one of my dually's rims have been replaced with another with another inch of backspacing. I now need to replace that one rim or the other five. I would like to match the one rim so I can run wider tires.
A tire shop found a set of six used rims that require an adapter ring and all new lugnuts. With those and 6 tires they want $1800.
Does anyone have a 5/8'" stud original rim that would match my other five or any other sources?
I'm curious as to what wheel you have that has an additional inch of backspacing. Does it have any manufacturers marks on it? As far as a stock wheel, they should be plentiful in wrecking yards across the country. If you live near North Texas, I've probably got one.
Good luck,
Casey
After talking with a tire shop, apparently, the other wheel is from a Chevy.
The wheel has been on the truck long enough and rotated such that the flat Chevy flange is flattening the Dodge Budd flares!
So, now I'm in the market for six new rims.
Does anyone know if they make steel rims with different backspacing with the Budd flange?
