Picked up a set of 275's dropped them in the truck and had a dead miss. Turns out one injector was not firing. Tried it in every cylinder with no luck. Had another injector sent for replacement, no luck. Injector number three, no luck. Took the original 5 plus the one I received Thurs to have tested. All 6 injectors popped at 4300-4350psi give or take a little and not below 4300psi.
My vendor has been great in all this and is stumped as well and trying like mad to help me figure out what is going on. The head man at the shop that tested them told me it could be my VP44 not puttin out enough pressure to pop them or an internal problem within the pump. How could that be when it can pop 5 of them?
Here's my questions
What is the pop pressure in a stock injector for my year model?
Can the 275's perform like they should with a pop pressure at 4100psi?
Is this an injector problem or possibly my VP44?
If I put the stock injectors back in all is well and runs like it always has. I did put the one injector that is not firing in with 5 of my stockers with no luck still a miss. I also took the spring and shim out of my stock injector and placed it in the 275 body with the 275 nozzle, again no luck. I asked about lowering the pop pressure thinking that maybe it will allow all 6 injectors to pop and allow me to utilize the added gains from them.
Has anyone experienced this? I am at a loss here trying to figure out or understand where to turn now and so is my vendor.
Thanks
Scott
Here's my questions
Thanks
Scott
