If I am reading pressure about 6 feet away from a point, how do I adjust my readings from what I am reading to what the actual pressure at the point is? Flowing fluid.
I have a VP fuel pressure sensor in a VP inlet return line (RASP) about 6 feet away from the VP inlet. Lines are AN-6 (3/8"), I have a reading of 13 psi. In the RASP return line there is generally a fluid flow through the check valve back to the tank. The pressure gauge is set in the line on the VP side of the bypass line and just before the bypass valve.
Seems like I read somewhere in the past that there is a . 75 psi drop per 10 feet of 3/8 rubber hose (effectively what AN-6 brained hose is) for flowing diesel due to hose friction. That would make the true reading at the Vp 13. 75 psi IF I have this right.
Is that about correct? The only way I have to verify the theory is to install a shrader valve at the VP44 inlet and I thought I would ask first before I embarked on that project.
Bob Weis
Bob Weis
