Truck has been low on power and setting a P0251 code for a while. The other day it died on me several times when I would roll to a stop. Had to crank it for about 10 seconds to get it to restart. Got it going, but no power. Took it to my diesel mechanic and he put the scanner on it and drove it. Did the tests related to 251 code and everything checked out. Had me take it to Dodge to see if their scanner would find an underlying problem. They did return flow test and it was was over spec. I think 800mL. Tightens connector tubes and now at 600mL,but still out of spec. Injectors were rebuilt at 113K and now I'm at 132K. Any ideas? This thing has me beat down. When it idles it tries to die, but catches itself at the last minute. Idle sticking at 1000 rpm and tech says when it does this the rail pressure is 7K and should be around 5K. FCA has been replaced w/no change. I need help bad. Been in the shop for a week and I've gotten nowhere, but poorer. Thinking ECM for the 251 code, but what is causing the excess return flow.
Sorry so long, just trying to give all the details.
