my a/c is slightly cool but wont get cold. the temp knob is not broke but on high the compressor clicks on and off constantly. it is like it's getting a signal that the temp control knob is at the lower side of the cool band. with all the controls on high ,shouldn't the compressor stay on for a while ??? one line of the a/c is ice cold and the other is hot. is there a sensor or etc. that might be going bad ??? could it be the actual temp control switch in the dash??? the problem just started today and was ice cold the last time a/c was used. also there are no leaks so i believe the system is fully charged. worked like new yesterday. any a/c techs. out there ???
94 2500 4X4 SLT LARAMIE,AUTOMATIC,170,000. MILES,ORDERED NEW,BRILLIANT BLUE/SILVER BOTTOM,7. 5ft. MEYERS POLYBLADE SNOWPLOW,12K REESE HITCH W/2 LIGHTS,30ft. FOURWINDS 5th WHEEL CAMPER W/15K REESE HITCH,CAR TRAILER,UTILITY TRAILER,K&N AIR,PUMP TURNED UP 20%,CAT. GUTTED,TST #5 250/635 PLATE SET FULL FORWARD,STAR WHEEL WIDE OPEN ,TST BOOST&EGT PILLAR MOUNT GAUGES,AMSOIL,RANCHO SHOCKS&STABILIZER,VENT SHADES,PRIME DESIGN(behind grille)BUG GUARD W/EYEBROWS,MOULDED MUD FLAPS,WINDOW TINT 15%,BEDLINER CUT TO FIT AROUND 5th. WHEEL HITCH RAILS,COBRA CB W/BOOMER AMP,102" STAINLESS WHIP,PA SYSTEM,SILENCER RING GONE,235X85X16 KELLY,3:54 REAR,BRITE-LITES(skeets design)** 2001 3500 QUAD 4X4 LOADED ON ORDER ( not parting with the 12v)
