Need some part numbers
Smarty jr. Questions
Airdog 100 Install question
Need part number for items 14, 15 and 8 in the diagram below. I have the Dodge manual but have not had much luck finding what i need. Anyone help me out?
I can provide the Cummins numbers for you this evening if that will help, deep in home improvement right now..... :rolleyes:
Mike. :)
Thanks Mike the Cummins numbers will be a big help. Tcdiesel what year manual did that diagram come from? I dont have that in my 06. looks like the plumbing has changed wonding if thats a 6. 7. The plumping on my 06 matches the cummins diagram.
tks
dave
That plumbing from T. C. 's pdf is most likely for a manual trans truck, no heat exchanger tee on it.
Mike. :)
#14 3967022 Hose
#15 3930310 Spring type hose clamp (2 required)
#8 is a washer, I suspect that it is shown in the wrong place in the drawing. I think the washer goes on the other end of the 90 degree fitting.
In case I am wrong the part number for the washer is 3974806.
Mike.
