Need Stacking Help ASAP!!
rpm flare at idle?
Dyno Day Put On By Mass Diesel 5/20
I have a Edge HOT box and I am goin to a dyno day this weekend. I have 2 other chips that I was thinking about stacking it with. The one is BullyDog Triple . Is that a good stack witht he edge hot tune?? Has anyone tried it if so how was it and what level did you run? And the other is a Superchip. I need to know asap so I can get one here to try to get over the 500/900 mark. THanks for everyones help and for looking.
I think you should tell us what year your truck is. I'm pretty sure that the Edge does pressure on some years and not on others.
If you want to get over the 500 mark, you better have a transmission upgrade, along with a good turbo and a pusher pump. That's what it took to get me over that mark. Along w/ my tst/ez stack. Just my $. 02
I have a edge attitude and bully dog crazy larry program. The edge is on level 5..... SERIOUS SMOKE AND POWER. aLSO RUNNING A PRO 52 CHARGER WITH BIG INJECTORS AND FILL TUBES. If you stack those two boxes u should be close... . good luck!
