Mike is right! However, If you open all four bleeder screws, and remove the cap to the master cylinder, the brake fluid will gravity drain. Similiar to taking your finger off the top of a straw filled with your favorite beverage! Just be sure to continue adding new fluid to the master cylinder. If you let it drain dry your in for a much bigger project.
When I replace my brake pads, rather than forcing the fluid back into the master cylinder I open the bleeder screws on the calipers and colapse the calipers forcing old fluid out the bleeder screw. Then top off the master cylinder. This assures fresh fluid is being rotated into the brake system.
Regards,
RK
98 Properly Valved 4x4 SWB QC ISB A/T Metallic Red w/ tan cloth interior, DC nerf bars, DC two piece mud-flaps, 275 h. p. injectors, Monroe Gas Magnums, Armor Tuff spray in bed liner, Goodyear Wrangler ATS 285/75r/16, BD Heavy Duty Valve body. Walker 21468 thru flow muffler,Cobra 29 NWST CB. American Racing Wheels.
[This message has been edited by Ram_Kowboy (edited 10-09-2000). ]
