Can an externel transmission filter be put into the line with out effecting anything ??? . What I want to install is a second trany cooler with an external filter , this transmission cooler will also have 3... 4x4 inch fans that can be turned on in the cab . I have pulled some steep grades in 1st and 2nd gear pulling a load and watched the temp exeed 220 degree,s , I cant see this system hurting . This will be mounted on the drivers side under the hood by the brake fluid reservoir ... ... . any comments please
