Need turbo oil return hose
04.5 lift pump ?'s
fleetguard FF5319 or FF5320
Does anyone know where you can buy a longer turbo oil return hose. I have an 03 and changed out the turbo, the hose needs to be about 2" longer, I have it on but the clamps are at the very end.
Another option would be going to the flex hose of the 04. 5 has anyone tried this, can it fit on without making changes to block. What are the part numbers of items needed
I called every diesel shop around nobody has anything, but all of our trucks have one.
When I installed my SPS 62/14 the stock black hose was a bit on the short side also, I went to the local Cummins place and bought a return hose for a '97 model truck. . red silicone and long enough so I don't have to worry about it slipping off, don't have the reciept handy so I do not have a part number for it. Maybe someone else here will know what it is... pricey lil' thing at $45 or so, but way cheaper then running the engine out of oil!:eek:
