RSchwarzli
So, it all started with the Crew Cab. Well, maybe not. Maybe it was the 1990 that started this problem. Well, not really if I think about it... . the project was just sitting there not using its turbo... .
Lets start at the beginning. The crew cab motor is built as follows:
1997 CPL 2174 180 HP pump
DDP stage 2 injectors
181 Taper cut PDR delivery valves
3000 GSK
Head studs
Cometic head gasket (might not be enough anymore... . may need to o ring
#10 plate
ATS exhaust manifold
Banks twin ram intake
PDR 2nd gen intercooler
60 PSI springs
HX35 (stock turbo) and HT3B 26 cm
Advanced timing (cant remember what I set it at... 17 deg sound right?? Hmmm)
Well, then last summer came. I was playing with the power in the 1990 too much and the EGTs started getting too high (273/650 @ wheels with stock H1C
). As I was heading accross country through the Rocky mountains at 20K lbs gross, I thought I turbo would be a wise option especially factoring in high altitude. So I "borrowed" the HX35 from the crew for a few weeks. Guess what? I like the HX35 on the DD. I like it on the daily alot and I dont want to give it back!
:-laf
So, it looks like it is time to get a new small turbo for the compound setup as its not coming off the daily.
I have all the options in the world. I was thinking maybe a PDR modified HX35 or S300, but maybe a ball bearing one would be nice... .
You see my motor specs and can see the amount of air I will need. I plan on doing towing, drag racing, and street driving with it.
What are your suggestions? What would you do in my shoes?
Robert
3000 GSK
Head studs
#10 plate
60 PSI springs
Robert
