Engine/Transmission (1994 - 1998) Need turbo!
Engine/Transmission (1998.5 - 2002) Funny noise coming from around the turbo
2nd Gen Non-Engine/Transmission Headlight Problems
I want a turbo that can do the following.
push . 78kg/sec of air at a PR of 2. 36 with an efficiency of 70-75%
and I want the turbo to weigh less than 48#
Who has some Ideas?
If you find one then you can look for one that
will runn 800+hp 1800lbs tq under 1000 deg egt's and 8-10 lbs of boost at an idle(should have no lag):p :p :p :p :p
I need one like that if it would add a little milage that would be cool too;) :D
Sorry DF could'nt resist:D
Jason, this is just for you. Using the turbo you already have or a T-66, slap on a T-88 to feed it 20 psi... ... . then hold on to your butt!
Turbo
Diesel Freak,
If it can be done, Pius at BELL TURBO, Stockton, Calif. is the man.
Phone# 209-467-8000... Let him know your TDR Member. . He's done some work for other members, and I'm running a hybrid H2E with a machined HX40 12cm2 housing... . So far so good. . Pius knows his stuff, and is great to work with.
Jay Wagner
